05-01-2017, 12:58 PM
Release Date: 21 Dec 2016
A-500 PRO
Firmware version: 01-05-161214-25-POP-430-802
http://files.syabas.com/popcornhour/firmware/a500pro/01-05-161214-25-POP-430-802.zip
Firmware Update Steps:
1. Unzip the downloaded file into the root directory of a USB thumb drive
2. Plug the USB thumb drive into USB port of A-500 PRO/A-500 PRO-U
3. Access to Setup->Maintenance in UI
4. Select Firmware Update and press Enter on the "Check For Firmware Update" button
5. If the file a500pro-update.bin/a500prou-update.bin is found in the USB thumb drive, it will prompt for firmware update
*Alternately you can access to Setup->Maintenance in UI to perform online update as well.
A-500 PRO
Citation :Release Notes:
- Added support on Full DVD Navigation
- Fixed ES9018K2M volume sometime could not be saved after reboot issue
- Improved the ES9018K2M DAC volume control performance
- Fixed some MKV encounter crash regression issue
- Added support for encoding auto detection on m3u and pls (ANSI, UTF16 and UTF16BE)
- Added support for encoding auto detection on lyrics (ANSI, UTF16 and UTF16BE)
- Fixed some VOBSUB entry show wrong color palette issue
- Fixed unable to show correct border color if text color is black color issue
- Fixed display wrong alpha value at some point during fading effect issue
- Fixed some SSA tag unable to apply if it appears after transform tag issue
- Added support for embedded font in MKV
- Added support for move tag in SSA or ASS
- Added support for SSA or ASS fading effect
- Fixed some ASS entry show wrong color regression
- Improved text subtitle collision handling
- Improved text rendering speed
- Fixed VOBSUB display wrong color palette regression
- Fixed some PGS entry stuck at display and unable to clear
- Fixed some DVD playback crash regression
- Improved handling on subtitle encoding auto detection (GB18030, BIG5, SJIS, EUC_KR, UTF8)
- Disabled gapless playback when channels are different
- Added support for cuesheet encoded in ANSI, UTF16 and UTF16BE playback
- Fixed crash happen when playback cue file with backslash appear in front of double apostrophe
- Fixed formatting problems for hard disk more than 2TB issue
- Fixed formatting HDD without NMT installed will not be able to auto set media destination issue
- Create 2GB swap partition if perform formatting using NMT Apps setup
- Mount NTFS with dirty-flag fix
- Fixed TV or Receiver tv modes are not updated when TV is turned on after player on issue
- Fixed some MKV has more than 32 embedded subtitles unable to show all subtitle streams issue
- Fixed some 3D SUBIDX entries unable to display issue
- Fixed some VOBSUB entries dropped issue
- Fixed some PGS entry unable to display when it has same start time as previous clear entry regression
- Fixed some MKV which has no any audio default flag encounter no audio output when start playback issue
- Fixed some ASS or SSA text subtitle overlapping and unclear issues
- Fixed BDMV filename with dot unable to detect external SUBIDX issue
- Fixed some text show incorrect color when alpha or color tag do not have H character in between and clip tag exist at the same time issue
- Fixed some audio and subtitle language code not shows as full text issue
- Added support for auto detection on ASS or SSA encoding
- Added support for M2TS subtitle track selection according to subtitle language
- Fixed certain SUBIDX and VOBSUB subtitles entry display time too long issue
- Fixed certain PGS some subtitles entry display time too long issue
- Fixed randomly encounter framework crash when playing BGM with photo slideshow issue
- Fixed audio stuttering issue during playback of BDMV or BDISO in downmix mode
- Added bookmark support for DVD
- Added external SUBIDX support for BDMV or BDISO
- Fixed choosing last audio track in MKV instead of first audio track when there is no any default flag issue
- Fixed certain MTS files show black screen when playback
- Fixed some FLAC unable to display embedded album art issue
- Improved HDMI handshake timing
- Fixed dizzy or flat effect on 3D subtitle display regression
- Fixed non-unicode SSA or ASS external subtitle follow UTF8 encoding issue
- Fixed always prompt user to login when list windows samba shares issue
- Added support for color name inside color tag in SRT and SMI
- Fixed syabas command server minor memory leaks issue
- Fixed SUBIDX and VOBSUB display wrong color palette issue
- Fixed PGS subtitle playback cause memory leaks issue
- Fixed 3D subtitles will show in wrong position when its x pos is less than 20px issue
- Fixed unable to display VOBSUB when playback with HEVC video codec issue
- Fixed MKV MVC, 4K H.264 playback regression issues
- Changed GB2312 to GB18030, and improve text subtitle encoding handling
- Fixed some H264 MKV encounter wrong detection and unable to start playback issue
- Fixed SMB shortcut unable to take effect after reboot if Username and Password input with remote control issue
- Fixed 4K H264 playback no video output issue
- Fixed certain MKV PGS unable to show subtitle issue
- Fixed some PGS subtitle entries display too fast issue
- Added bitrate changing info for BD, DVD and M2TS issue
- Added audio and subtitle language indicator for M2TS and bdlite
- Fixed some SRT has long subtitle entry showing extra empty lines after word wrapping handling issue
- Fixed MKV and MP4 encounter random crash when first start or stop playback issue
- Fixed some text based subtitle may cause framework crash issue
- Fixed 720p24 clip play in tvmode 720p60 instead of 1080p24 when external video scaler is on issue
- Fixed DVD without video_ts folder unable to start playback issue
- Fixed 3D BDISO unable to continue playback after iframe forward or backward issue
- Fixed UTF8 text subtitle display style at wrong segment position issue
- Fixed unable to access NMJ through file browser issue
- Fixed some DVDLITE playback has no audio output issue
- Added language indicator on subtitle menu for DVD and MKV
- Fixed filename with xml escaped symbol unable to start playback issue
- Fixed SACD ISO with unknown title or artist cause framework reboot when playback twice consequently issue
- Fixed certain MKV PGS with heavy animated effects cause buffering issue
- Fixed wrong chinese translation for subtitle track issue
- Fixed SRT with an9 tag causing framework reboot when adjust y position issue
- Added italic, bold, underline and color tag handling for SMI
- Fixed color tag unable to display properly for certain languages issue
- Fixed sometimes unable to retrieve weather information correctly in Setup Wizard issue
- Fixed MKV invoke closing PGS function in text base subtitle playback issue
- Force system to perform clean reboot instead of restart framework when framework crash
- Fixed MKV which has forced subtitle unable to start playback if forced subtitle only option is selected
- Fixed certain MKV with SRT subtitle playback cause framework reboot issue
- Integrated new Sigma Designs SDK with playback engine and HDMI driver update
- Fixed some DVDLITE has wrong sequence of audio streams issue
- Fixed some MKV PGS subtitle entries display too fast issue
- Fixed some MKV x264 playback has no video display issue
- Fixed some zlib compressed PGS subtitle stream unable to display properly issue
- Fixed APE version greater than 3.99 unable to start playback issue
- Fixed DVDLITE unable to go to the next chapter with info bar turn on issue
- Fixed showing exclamation mark and unable to display lite menu when select same DVDLITE title issue
- Fixed DVDLITE get video freeze forever after seek till end of the clip issue
- Fixed DVDLITE title menu subtitle selection issue
- Fixed some JPG crash in zoom transition issue
- Fixed MKV encounter crash when repeat playback issue
- Fixed unable to set device name without NMT app installed issue
- Fixed MKV audio menu show undetermined for und tag issue
- Fixed DVD show wrong elapsed time after seek and sometimes playback from beginning when perform 10% or 20% seek issue
- Fixed MKV encounter crash when manually turn on external text subtitle issue
- Fine tuned MMS prebuf and underrun buffer
- Fixed SMB share showing invalid login after removing username and password in edit share
- Enhanced handling for DVDLITE module
- Update to new kernel to support SSD formatting and MMC 5.0
- Optimized PGS subtitle rendering speed to support special PGS subtitle effect
- Fixed video with framerate 25fps output wrong tv mode when external video scaler turned on issue
- Added MMS Internet Radio support
- Fixed MP3 Internet Radio streaming issue
- Fixed for some APE playback cause framework crash and some APE with ID3 tag unable to start playback issue
- Fixed for APE with ID3 tag unable to get metadata info issue
- Fixed for some MKV VOBSUB unable to display subtitle issue
- Fixed for some SACD ISO unable to perform seek issue
- Added Genre and Channels info for get_current_aod_info API
- Added language indication for BD or DVD or MKV Audio menu switching
- Fixed for some DVD ISO encounter crash at starting of playback issue
- Fixed FLAC ID3 album art not displayed in Music Home issue
- Always show device name option at preference settings
- Fixed unable to save username or password when edit samba shared issue
- Added MKV audio default flag handling
